Введение
This guide will show how to access your DVD drive.
Запчасти
Детали не указаны.
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: step 2, image 1 of 3 Dell Inspiron 1521 DVD Drive Replacement: step 2, image 2 of 3 Dell Inspiron 1521 DVD Drive Replacement: step 2, image 3 of 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: step 3, image 1 of 2 Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: step 3, image 2 of 2
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: step 4, image 1 of 3 Dell Inspiron 1521 DVD Drive Replacement: step 4, image 2 of 3 Dell Inspiron 1521 DVD Drive Replacement: step 4, image 3 of 3
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Заключение
Rogelio Ordonez
Участник с: 26.09.2012
54 Репутация
Автор 2 руководств
Cal Poly, Team 15-47, Forte Fall 2012 Участник Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 членов
Автор 9 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 960
