Dell Inspiron 1545 Computer Processing Unit Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: шаг 1, изображение 1 из 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 2, изображение 1 из 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 3, изображение 1 из 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: шаг 4, изображение 1 из 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 5, изображение 1 из 2 Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 5, изображение 2 из 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: шаг 6, изображение 1 из 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 7, изображение 1 из 1
    • Pull up on the Heat Sink unit to remove it.
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: шаг 8, изображение 1 из 1
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: шаг 9, изображение 1 из 1
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
Заключение
8 человек успешно провели ремонт по этому руководству.
Nathan Lemay
Участник с: 04/16/14
3 145 Репутация
Автор 15 руководств
Команда
Cal Poly, Team 9-14, Regan Spring 2014 Участник Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 членов
Автор 15 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 3,017
