Dell Inspiron 1545 Power Button Board Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 1545 Power Button Board Replacement, Power Button Board: шаг 1, изображение 1 из 1
    • Turn the laptop off and disconnect it from all power sources.
    • Turn the laptop over so that the bottom is facing upwards.
  2. Dell Inspiron 1545 Power Button Board Replacement: шаг 2, изображение 1 из 1
    • Slide the release latch while simultaneously pulling the battery outwards.
  3. Dell Inspiron 1545 Power Button Board Replacement: шаг 3, изображение 1 из 1
    • Slide the battery completely out of the bay.
  4. Dell Inspiron 1545 Power Button Board Replacement: шаг 4, изображение 1 из 1
    • Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
  5. Dell Inspiron 1545 Power Button Board Replacement: шаг 5, изображение 1 из 1
    • Flip the laptop back over to the front and push the screen open as far as possible.
  6. Dell Inspiron 1545 Power Button Board Replacement: шаг 6, изображение 1 из 3 Dell Inspiron 1545 Power Button Board Replacement: шаг 6, изображение 2 из 3 Dell Inspiron 1545 Power Button Board Replacement: шаг 6, изображение 3 из 3
    • The center control cover is very fragile; be careful when prying it off.
    • Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
    • Carefully lift the central control cover away from the laptop.
  7. Dell Inspiron 1545 Power Button Board Replacement: шаг 7, изображение 1 из 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Power Button Board Replacement: шаг 8, изображение 1 из 1
    • Be careful when pulling the keyboard away from the laptop, you may damage the connector holding it to the motherboard.
    • Using your hands, push the keyboard out and away from the laptop.
  9. Dell Inspiron 1545 Power Button Board Replacement: шаг 9, изображение 1 из 2 Dell Inspiron 1545 Power Button Board Replacement: шаг 9, изображение 2 из 2
    • Lift the connector latch to remove the keyboard cable from the motherboard.
    • Lift the keyboard away from the laptop.
  10. Dell Inspiron 1545 Power Button Board Replacement: шаг 10, изображение 1 из 1
    • Lift the connector latch to remove the power button board from the motherboard.
    • Pull on the blue plastic tab to help prevent causing any damage to the connector.
  11. Dell Inspiron 1545 Power Button Board Replacement: шаг 11, изображение 1 из 1
    • Pry the power button board out with your finger.
    • Pull the power button board away from the laptop.
Заключение
Michael Hill
Участник с: 02/28/18
193 Репутация
1 руководство автора
Команда
University of Memphis, Team S5-G9, Baddour Spring 2018 Участник University of Memphis, Team S5-G9, Baddour Spring 2018
UM-BADDOUR-S18S5G9
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 37
За всё время: 2,196
