Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: шаг 2, изображение 1 из 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: шаг 3, изображение 1 из 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Bracket: шаг 5, изображение 1 из 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Align the Screw Holes: шаг 6, изображение 1 из 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: шаг 7, изображение 1 из 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: шаг 8, изображение 1 из 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: шаг 9, изображение 1 из 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: шаг 10, изображение 1 из 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Финишная черта
Terrence15
Участник с: 12/18/17
79 555 Репутация
Автор 441 руководств
Команду
RampUP America, Inc. Участник RampUP America, Inc.
Community
43 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 973
