Введение
Welcome to our guide on how to replace your Dell laptop's battery. We understand that not everyone is a tech expert, and that's perfectly fine. This guide is here to walk you through the process of replacing your laptop's battery in a clear and easy-to-follow manner. Tools and Parts are also mentioned. This is required incase if your battery is not performing to the best ability.
Выберете то, что вам нужно
Before starting, make sure the laptop is powered off and disconnected from any power sources.
Remove the Screws of the Laptop with help screwdriver.
There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
Carefully disconnect the old battery from the motherboard.
Gently remove the old battery from its housing by removing plug of battery.
Insert the new battery into the housing.
Connect the new battery to the motherboard.
Securely reattach the battery back cover.
Plug in the laptop and charge it to Full Capacity.
Power on the laptop and make sure it works with the new battery.
2 участников успешно повторили данное руководство.
