Введение
The hard drive is where all the data of the laptop is stored. Without it, or with a broken one, users' devices will not function at all. This guide will show the steps to replace the hard drive on this device.
Выберете то, что вам нужно
Remove the two 6.5 mm PH1 Philips head screws on the back panel.
Lift up the small panel from the top, using the plastic opening tools if necessary.
Remove the two 5.5 mm PH1 Phillips head screws holding in the hard drive.
Slide the hard drive out of its slot and lift it out of the device.
