Введение
Malfunctioning keys or a completely broken keyboard can render a laptop useless to the user. This guide will show the steps to replace the keyboard of this device.
Выберете то, что вам нужно
Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
After prying the tabs up, carefully pull the keyboard out of the laptop.
Once the keyboard is lifted, locate the release tab.
Using a plastic opening tool or your finger, lift the tab so that it opens .
Once the tab is open, the strip on the keyboard can be removed.
Еще один человек закончил это руководство.
Remove all screws on the underside, remove the RAM and Hard Drive, and all case screws around the Hard Drive bay
Richard Holmes - Ответить
