Введение
This guide will show how to access and replace the speakers in this laptop. Simple tools are required. Be gentle when removing parts with ribbon cables.
Выберете то, что вам нужно
Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
Slide the Optical Drive out of the device.
Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
Remove the 2.5 mm Phillips #0 screw securing the hard drive.
Slide the hard drive out using the pull tab.
Remove the hard drive from the device.
Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
Gently detach the cable and the keyboard from the laptop.
Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
Remove the palm rest from the device.
Еще один человек закончил это руководство.
