Введение
This guide will allow you to replace a broken keyboard for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
Инструменты
Запчасти
Детали не указаны.
Find the battery release latch on the bottom side of the computer.
Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
Afterwards, carefully detach the backlight cable from the laptop.
Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
Afterwards, carefully slide the cable out of its slot.
2 участников успешно повторили данное руководство.
