Введение
This is a replacement guide for the Dell Inspiron 17-7737 hard disk drive. The hard drive is the long-term memory and archive of a computer and is one of a computer's most essential parts in working conditions.
Disclaimer: Please be cautious in regard to swollen batteries, as battery acid is extremely toxic to humans, any puncture or leak can be a major issue if left unnoticed or unresolved.
Выберете то, что вам нужно
Close the display and turn the computer over.
Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
Using the adhesive pull tab, pull and lift the battery out of the computer's base.
Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
Еще один человек закончил это руководство.
