Введение
Possibly one of the only components that can be interchangeable with other devices, if you're looking for a quick replacement. Remember, black wire to black slot, white wire to white slot.
Выберете то, что вам нужно
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
Remove the black wired connection from the port over the black triangle.
Remove the wire with the white marking from the port above the white triangle.
Pull the Wi-Fi card out of its slot.
