Введение
You may want to remove the hard drive to upgrade to a higher capacity drive or if your files have become corrupted and unrecoverable.
Выберете то, что вам нужно
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Locate the battery lock switch.
Slide the lock switch to the left (away from the lock symbol).
Slide the battery out away from the laptop.
Remove the two 1mm double wide Phillips #00 screws.
Pull the hard drive away from the laptop.
Remove the two #00 1mm screws on both sides of the hard drive.
Pull the hard drive cover away from the hard drive and set the cover aside.
3 участников успешно повторили данное руководство.
