Введение
It is useful to to replace the hard drive if your computer has become slow or if your programs freeze or crash.
  1. Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the one 2mm Phillips #00 screw on the module cover. Use the plastic opening tool to lift the module cover. Use the plastic opening tool to lift the module cover.
    • Remove the one 2mm Phillips #00 screw on the module cover.
    • Use the plastic opening tool to lift the module cover.
  5. Pull the metal tabs away from the RAM chip to release it from the motherboard. Pull the chip up from the laptop.
    • Pull the metal tabs away from the RAM chip to release it from the motherboard.
    • Pull the chip up from the laptop.
    • Use the plastic opening tool to lift the chip out if it's difficult to do with your hands.
    • Repeat this process for the RAM chip directly beneath the last one.
Заключение
2 участников успешно повторили данное руководство.
Tina Rickard
Участник с: 07.04.2014
717 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 6
За всё время: 1,517
