Введение
This guide will show you how to replace the speakers of a Dell Inspiron 17R-5737. The speakers are often replaced when your computer is having issues with audio playback. To replace the speakers, you must first disassemble a vast majority of the laptop.
Выберете то, что вам нужно
Remove one 4.8mm screw with a JIS #00 screwdriver.
Remove the optical drive.
Remove two 4.8mm screws with a JIS #00 screwdriver.
Remove the access panel.
Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
Slide the hard drive to the left.
Slide the hard drive to the right and up.
Slowly lift the keyboard.
Lift the locking flap that holds the ribbon cable in place.
Remove the keyboard.
Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
Remove six 4.8mm screws with a JIS #00 screwdriver.
Remove two 3.2mm screws with aJIS #00 screwdriver.
Disconnect three cables from the front of the motherboard.
Slowly lift the motherboard exposing the bottom side.
Remove the ribbon cable from the back of the motherboard.
Remove the motherboard.
Remove two 1.6mm screws on each speaker with a JIS #00 screwdriver.
Remove the speakers.
