Введение
If you have narrowed down the cause of your laptop's problems to the battery, this guide will explain how to remove and replace your battery to restore normal function to your device. Replacing the battery is very simple.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
Slide both the left lock and right lock, towards the center of the battery.
Push upwards on the grip on the bottom of the battery to remove it.
3 участников успешно повторили данное руководство.
