Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95-
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
Slide both the left lock and right lock, towards the center of the battery.
Push upwards on the grip on the bottom of the battery to remove it.
Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
Tilt the metal jimmy away from you to pry up the edge of the keyboard.
Repeat the previous actions on each of the other three holes to release the keyboard.
Gently flip the keyboard over and lay it on the touchpad area.
Flip up the black flap where the keyboard cable connects to the motherboard
Gently pull the cable away from the slot to release the keyboard.
Remove the keyboard from the device.
Flip the laptop over so it is bottom-up.
Use a Phillips #0 screwdriver to unscrew the fifteen 5mm screws pictured.
Use a Phillips #0 screwdriver to unscrew the four 5mm screws from the palmrest.
Flip up the black flaps over the three cables pictured and gently pull them out.
Use a plastic opening tool to pry up the edges of the palmrest cover.
Pull off the palmrest cover. You will hear some popping sounds.
Optical drive MUST be removed beforehand: remove the screw on bottom of laptop on the small panels that has the service tag number. Then use a paperclip to eject the drive and pull it out. This reveals the two small silver screws that attach the top cover. Remove those screws prior to prying off the cover.
Use a Phillips #0 screwdriver to unscrew the two 5mm screws holding the hard drive.
Slowly lift up on the left side of the hard drive and pull to the left.
16 участников успешно повторили данное руководство.
5 Комментариев
Good guide, but missing a step. In the one I disassembled, the optical drive needed to be removed (it just slides out), and two screws that were holding in the keyboard needed to be removed before the keyboard would come out.
Yes that step is ESSENTIAL. Had I known that, I’d have saved 15 minutes as I tried to remove the top cover without destroying my client’s laptop. Really unfortunate to not have that step included NOW, it really can’t be isolated in the comments.
frank -
