Введение
Use this guide to remove the back panel in order to access internal components or replace the panel.
Выберете то, что вам нужно
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
2 участников успешно повторили данное руководство.
