Введение
Is your computer heating up easily or getting louder? Consider using this guide to replace the fan in your device.
Выберете то, что вам нужно
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
If there is tape on your fan, remove the tape.
Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
