Введение
Is your computer experiencing problems with connecting to the Wi-Fi or the internet? Consider using this guide to replace the WLAN card in your device.
Выберете то, что вам нужно
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
Еще один человек закончил это руководство.
