Введение
Follow these steps to disassemble the computer, access the heat sink, and replace the part.
Выберете то, что вам нужно
Slide the latches on both sides of the computer outward to unlock the battery.
Remove the battery from the computer.
Remove the screw. (1 x m2 x 3mm)
Move the hard drive to the open area and remove it.
Unplug the black and white antenna cables from the wireless card.
Remove the screw. (1 x M2 x 3mm)
Remove the wireless card from the laptop.
Turn over the laptop and open it.
Use the plastic prying device to release the keyboard.
Lift the keyboard.
Unplug the cable connecting the keyboard to the laptop.
Remove the keyboard.
Remove the screws. (3 x M2.5 x 5mm)
Carefully unsnap the palm rest from the rest of the laptop.
Remove the palm rest.
Unplug the cable that connects to the motherboard.
Remove the DC jack from the laptop.
Remove the screws. (1 x M2 x 3mm)
Unplug the circuit board from the rest of the computer.
Unplug the cable on the bottom part of the mother board.
Remove the motherboard from the laptop.
Turn over the motherboard.
Unplug the cooling fan.
Loosen the 3 screws from the heat sink.
Remove the heat sink.
2 участников успешно повторили данное руководство.
