Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
You will be removing the keyboard to either replace or access various parts of the laptop.
Запчасти
Детали не указаны.
  1. Remove battery
    • Remove battery
    • Open screen so that it lies flat.
  2. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it.
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard. Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Lift keyboard and detach the interface connector.
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
Заключение
Еще один человек закончил это руководство.
May Chauvin
Участник с: 14.04.2011
201 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 12-34, Maness Spring 2011 Участник Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 3,225
