Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Flip the laptop on it's back, so that the bottom is facing up.
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Loosen the single Phillips #1 screw.
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Push the highlighted pin outward until the RAM pops slightly out of its socket. Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible. Not seating the new DIMMs correctly could cause the device to refuse to POST.
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Заключение
2 участников успешно повторили данное руководство.
May Chauvin
Участник с: 14.04.2011
201 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 12-34, Maness Spring 2011 Участник Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 4,011
