Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is to replace the DC Jack in a Dell Inspiron 5758 laptop. Ensure you have all replacement parts and tools needed for this step-by-step replacement guide.
Выберете то, что вам нужно
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Slide the battery release switch towards the unlock icon.
Lift and pull the ejected battery to remove it.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Unplug the hard drive cable.
Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
Remove the four 8 mm screws.
Remove the hard drive.
Remove the two 3 mm screws under the battery.
Remove the three 2 mm wafer screws under the optical drive.
Remove the ten 8 mm base screws.
Press in the tabs to loosen the keyboard.
Carefully lift the keyboard up and turn it over.
Remove the one 5mm screw.
Lift the circuit board & turn it over.
Unplug the cable.
Remove the audio/USB circuit board.
Loosen the audio / USB cable.
Remove the one 3mm motherboard screw.
Lift the motherboard & carefully move it out of the way.
Еще один человек закончил это руководство.
