Введение
This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
  • Battery
  • Hard Drive
  • DC Jack
  • Keyboard
  1. Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Slide the battery release switch towards the unlock icon.
    • Slide the battery release switch towards the unlock icon.
      • You should hear a click.
    • Lift and pull the ejected battery to remove it.
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
    • Remove the one 3 mm screw.
    • Remove the bracket.
    • Unplug the antenna cables.
    • Remove the Wireless Card.
    • Unplug the hard drive cable.
      • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
    • Unplug the speaker cable by sliding to the right.
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
    • Unplug the keyboard cable & remove the keyboard.
    • Slide the DVD optical drive over & remove it from the laptop.
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
    • Unplug the power button cable.
    • Unplug the touchpad cable.
    • Carefully pry off & loosen the bottom base.
    • Remove the bottom base.
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
    • Release the antenna cable tape.
    • Release the antenna cables.
    • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
    • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
    • Open the hinges carefully and remove the LCD display assembly.
    • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
    • Loosen the cable and remove the power button circuit board.
    • Push up on the touchpad to release it from the housing.
    • Remove the touchpad.
    • Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
      • The bezel may require some force to unsnap.
    • When you have removed the LCD bezel, place it to the side.
    • Remove the ten 4.5mm screen screws.
      • There is one screw in the top left, one screw in the top right, four in the bottom left, and four in the bottom right.
    • Lift the LCD screen from the display assembly, flip the LCD screen over, and place the screen face down.
    • Unplug the LCD cable.
    • Place the display assembly to the side.
    • Remove the three 3mm screws that connect each hinge rail to the LCD screen.
    • Remove the hinge rails.
      • There are two hinge rails, one on the left edge of the screen and one on the right edge.
Заключение
Blase Martin
Участник с: 18.09.2018
296 Репутация
Автор 2 руководств
Команда
University of North Texas, Team S3-G4, Raign Fall 2018 Member of University of North Texas, Team S3-G4, Raign Fall 2018
UNT-RAIGN-F18S3G4
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 34
За всё время: 70
