Введение
This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
- Battery
- Hard Drive
- DC Jack
- Keyboard
Выберете то, что вам нужно
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Slide the battery release switch towards the unlock icon.
Lift and pull the ejected battery to remove it.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Unplug the hard drive cable.
Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
Remove the four 8 mm screws.
Remove the hard drive.
Remove the two 3 mm screws under the battery.
Remove the three 2 mm wafer screws under the optical drive.
Remove the ten 8 mm base screws.
Press in the tabs to loosen the keyboard.
Carefully lift the keyboard up and turn it over.
Remove the one 5mm screw.
Lift the circuit board & turn it over.
Unplug the cable.
Remove the audio/USB circuit board.
Loosen the audio / USB cable.
Remove the one 3mm motherboard screw.
Lift the motherboard & carefully move it out of the way.
Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
Open the hinges carefully and remove the LCD display assembly.
Remove the one 2mm wafer screw using Phillips #0 screwdriver.
Loosen the cable and remove the power button circuit board.
Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
When you have removed the LCD bezel, place it to the side.
Lift the LCD screen from the display assembly, flip the LCD screen over, and place the screen face down.
Unplug the LCD cable.
Place the display assembly to the side.
Remove the three 3mm screws that connect each hinge rail to the LCD screen.
Remove the hinge rails.
2 человек успешно провели ремонт по этому руководству.
