Введение
This guide will show you how to replace the touchpad on the Dell Inspiron 5758.
Выберете то, что вам нужно
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Slide the battery release switch towards the unlock icon.
Lift and pull the ejected battery to remove it.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Unplug the hard drive cable.
Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
Remove the four 8 mm screws.
Remove the hard drive.
Remove the two 3 mm screws under the battery.
Remove the three 2 mm wafer screws under the optical drive.
Remove the ten 8 mm base screws.
Press in the tabs to loosen the keyboard.
Carefully lift the keyboard up and turn it over.
Remove the one 5mm screw.
Lift the circuit board & turn it over.
Unplug the cable.
Remove the audio/USB circuit board.
Loosen the audio / USB cable.
Remove the one 3mm motherboard screw.
Lift the motherboard & carefully move it out of the way.
Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
Open the hinges carefully and remove the LCD display assembly.
Remove the one 2mm wafer screw using Phillips #0 screwdriver.
Loosen the cable and remove the power button circuit board.
2 участников успешно повторили данное руководство.
