Введение
Replacing the screen takes some time and effort, but requires few tools.
Выберете то, что вам нужно
Push the switch next to the battery.
At the same time, lift the battery away from the laptop.
Place the laptop on flat surface.
Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
Carefully take a spudger and separate part of the cover at the red circle.
Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
Use the plastic opening tools to remove the six rubber screw covers in the corners.
Remove six 4 mm #00 Philips screws located in the corners.
Insert the plastic opening tools between the screen holders.
Go completely around the screen, separating the screen holders with the plastic opening tools.
3 участников успешно повторили данное руководство.
