Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This is a quick and easy process.
Выберете то, что вам нужно
Flip laptop upside down and locate the battery as shown in the images.
Push in the tab on the battery and lift up. The battery should detach very easily.
Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports.
Using #00 screwdriver, unscrew locking screw.
Push in on button directly beneath screw. A tab should pop out as shown in picture 2.
Pull out on tab to remove disk drive.
