Dell Inspiron 7000 2 in 1 Battery Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 2, изображение 1 из 1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 3, изображение 1 из 3 Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 3, изображение 2 из 3 Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 3, изображение 3 из 3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 4, изображение 1 из 1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 5, изображение 1 из 1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 6, изображение 1 из 1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 7, изображение 1 из 1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 8, изображение 1 из 1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 9, изображение 1 из 1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: шаг 10, изображение 1 из 1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Финишная черта
3 участников успешно повторили данное руководство.
Neelay Patel
Участник с: 09/17/21
255 Репутация
1 руководство автора
Команда
York University, Team E-31, Melo-Thaiss Fall 2021 Участник York University, Team E-31, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG31
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 30
За последние 30 дней: 168
За всё время: 5,656
