Выберете то, что вам нужно
Remove the battery by sliding and holding the battery release latch.
Use a plastic flat screwdriver to slide the hinge caps away from the computer.
Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
Carefully, lift the hinge cover from the main unit and remove it from the main unit.
Почти готово!
Заключение
