Введение
If your Dell Inspiron 7306 P125G or Inspiron 7306 2-in-1 won't power on, this guide will help replace the battery as a solution for power problems with the laptop. Before continuing, consult the swollen battery and removing power/disconnecting tips to ensure your safety.
Выберете то, что вам нужно
Turn off the laptop with the power button and close it.
Disconnect any power sources from the laptop.
Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
Grab a corner of the back cover or use a spudger to lift the cover.
Pull the cover up around the edges until it is completely removed.
Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
Insert the new battery. Align the holes of the screwdriver with the center object.
Apply the tape from the wires to the battery once more.
Ensure that the cover snaps into place when closing the back cover.
Еще один человек закончил это руководство.
