Введение
By following the steps in this guide one should be able to replace the battery on the device (Dell Inspiron 7568).
Выберете то, что вам нужно
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Remove the four 3mm Phillips #1 screws holding the battery.
Unhinge the connector cable to the battery.
Remove the battery.
5 участников успешно повторили данное руководство.
