Введение
By following the steps in this guide one should be able to replace the trackpad on your device (Dell Inspiron 7568)
Выберете то, что вам нужно
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Remove the four 3mm Phillips #1 screws holding the battery.
Unhinge the connector cable to the battery.
Remove the battery.
Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
Remove the touchpad bracket
Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
Unscrew & remove the three 2mm wafer screws holding the touchpad.
Remove the touchpad.
2 участников успешно повторили данное руководство.
