Введение
First you must remove the hinge cover than keyboard lower case and finally have access to the cooling fan.
Запчасти
No parts specified.
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Remove the screws on the top right of the bottom of the laptop. Once screws are removed, the fan can easily be slid out of its position. Once screws are removed, the fan can easily be slid out of its position.
    • Remove the screws on the top right of the bottom of the laptop.
    • Once screws are removed, the fan can easily be slid out of its position.
Заключение
John Nesthus
Участник с: 13.04.2011
186 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 3,152
