Введение
Follow this guide to remove the LCD Display.
Выберете то, что вам нужно
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Pull the small black tab on the right hand side of the laptop.
You have now removed the hinge cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
Disconnect the video card from the display module by gently lifting upwards on the black tab.
First, remove the plastic tabs that are covering the interior screws.
After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
Note there are 8 tabs and 8 screws in total.
Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
2 участников успешно повторили данное руководство.
