Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Pull the small black tab on the right hand side of the laptop.
You have now removed the hinge cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
Disconnect the video card from the display module by gently lifting upwards on the black tab.
Lift the display module directly upwards from the base of the computer.
First, remove the plastic tabs that are covering the interior screws.
After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
Note there are 8 tabs and 8 screws in total.
Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
Using a Philips #1 screwdriver remove the screws holding the LCD in place.
2 участников успешно повторили данное руководство.
