Введение
We are going to show you how to remove the lower case, how to remove the components, how to put them back in and finally how to attach the upper case back onto the lower case.
Запчасти
No parts specified.
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off. Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover. Be careful of wire attached to underside of the hinge cover.
    • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
    • Be careful of wire attached to underside of the hinge cover.
  3. Pull the small black tab on the right hand side of the laptop.
    • Pull the small black tab on the right hand side of the laptop.
    • The hinge cover has now been removed.
  4. Remove the screws at the top of the keyboard as indicated indicated. Do not just lift up, there is a tab underneath the keyboard that is still connected to the mother board. You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • Remove the screws at the top of the keyboard as indicated indicated.
    • Do not just lift up, there is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Flip the laptop over and remove the indicated screws. Flip the laptop back over.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  7. Disconnect the video card from the display module by gently lifting upwards on the black tab.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  8. Lift the display module directly upwards from the base of the computer. Lift the display module directly upwards from the base of the computer.
    • Lift the display module directly upwards from the base of the computer.
  9. The display module has been removed.
    • The display module has been removed.
  10. Remove the two screws holding down the upper case.
    • Remove the two screws holding down the upper case.
  11. Remove the metal bar which connects the motherboard to the lower case. Remove the metal bar which connects the motherboard to the lower case.
    • Remove the metal bar which connects the motherboard to the lower case.
  12. Disconnect the optical disk drive by gently pulling upward.
    • Disconnect the optical disk drive by gently pulling upward.
  13. Remove the optical disc drive by pushing a small release button on the side of the laptop and then pulling it. This will uncover one final screw that will need to be removed. This will uncover one final screw that will need to be removed.
    • Remove the optical disc drive by pushing a small release button on the side of the laptop and then pulling it.
    • This will uncover one final screw that will need to be removed.
  14. You can now pop off the lower case for replacing.
    • You can now pop off the lower case for replacing.
Заключение
John Nesthus
Участник с: 13.04.2011
186 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 6
За всё время: 3,253
