Введение
We will show you how to remove and replace the hinge cover which houses the power button.
Выберете то, что вам нужно
Locate the small opening at the upper left of the top blue panel which houses the power button.
Use a spudger to lift up and remove the blue panel.
Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
You should now be able to completely remove the hinge cover.
3 участников успешно повторили данное руководство.
