Dell Inspiron 8600 Touch Pad Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 8600 Touch Pad Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: шаг 2, изображение 1 из 3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: шаг 2, изображение 2 из 3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: шаг 2, изображение 3 из 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Touch Pad Replacement: шаг 3, изображение 1 из 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Touch Pad Replacement, Keyboard: шаг 4, изображение 1 из 3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: шаг 4, изображение 2 из 3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: шаг 4, изображение 3 из 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Touch Pad Replacement, Display Module: шаг 5, изображение 1 из 2 Dell Inspiron 8600 Touch Pad Replacement, Display Module: шаг 5, изображение 2 из 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Touch Pad Replacement: шаг 6, изображение 1 из 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Touch Pad Replacement: шаг 7, изображение 1 из 2 Dell Inspiron 8600 Touch Pad Replacement: шаг 7, изображение 2 из 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Touch Pad Replacement: шаг 8, изображение 1 из 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Touch Pad Replacement, Touch Pad: шаг 9, изображение 1 из 1
    • Pop the upper case off, and replace.
Заключение
John Nesthus
Участник с: 04/13/11
186 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 18-22, Garner Spring 2011 Участник Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 3,027
