Dell Inspiron 910 Speaker Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 910 Speaker Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speaker Replacement, Keyboard: шаг 2, изображение 1 из 1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speaker Replacement: шаг 3, изображение 1 из 1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speaker Replacement, Speaker: шаг 4, изображение 1 из 1
    • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speaker Replacement: шаг 5, изображение 1 из 1
    • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speaker Replacement: шаг 6, изображение 1 из 1
    • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
    • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speaker Replacement: шаг 7, изображение 1 из 1
    • Slide out the cables connected to the speakers and the base below the keyboard.
    • Remove the speakers from the laptop.
Заключение
3 участников успешно повторили данное руководство.
Kyle Beekman
Участник с: 04/05/12
144 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 14-10, Forte Spring 2012 Участник Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 18
За всё время: 1,540
