Dell Inspiron 910 Web Camera Replacement
Выберете то, что вам нужно
  1. Dell Inspiron 910 Web Camera Replacement, Screen: шаг 1, изображение 1 из 1
    • Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
  2. Dell Inspiron 910 Web Camera Replacement: шаг 2, изображение 1 из 1
    • Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
  3. Dell Inspiron 910 Web Camera Replacement: шаг 3, изображение 1 из 1
    • Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
    • Unscrew the 4 screws from the two strips.
    • While unscrewing the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
  4. Dell Inspiron 910 Web Camera Replacement: шаг 4, изображение 1 из 1
    • Gently lay the screen down, being careful not to damage the ribbon connector.
  5. Dell Inspiron 910 Web Camera Replacement: шаг 5, изображение 1 из 1
    • Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
  6. Dell Inspiron 910 Web Camera Replacement: шаг 6, изображение 1 из 1
    • Pull the screen out. Congratulations! You have removed the screen.
  7. Dell Inspiron 910 Web Camera Replacement, Web Camera: шаг 7, изображение 1 из 1
    • Remove the two small screws above the screen at the center of the lid.
  8. Dell Inspiron 910 Web Camera Replacement: шаг 8, изображение 1 из 1
    • Insert the replacement webcam module so the two screws match up with the two holes in the module.
  9. Dell Inspiron 910 Web Camera Replacement: шаг 9, изображение 1 из 1
    • Replace and tighten the two screws so that the module is held in place.
  10. Dell Inspiron 910 Web Camera Replacement: шаг 10, изображение 1 из 1
    • Carefully connect the ribbon cable running along the back of the screen to the appropriate docking station in the webcam module.
Заключение
Arnesh Mudaliar
Участник с: 04/03/12
8 Репутация
1 руководство автора
Команда
Cal Poly, Team 14-10, Forte Spring 2012 Участник Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 18
За всё время: 1,836
