Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
Unscrew the 4 screws from the two strips.
Gently lay the screen down, being careful not to damage the ribbon connector.
Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
Pull the screen out. Congratulations! You have removed the screen.
Remove the two small screws above the screen at the center of the lid.
Insert the replacement webcam module so the two screws match up with the two holes in the module.
Replace and tighten the two screws so that the module is held in place.
Carefully connect the ribbon cable running along the back of the screen to the appropriate docking station in the webcam module.
