Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
Запчасти
Детали не указаны.
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M." This screw will remain in the panel.
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
  5. Use your fingertips to carefully spread apart the plastic white tabs. Flip the RAM up at a 45 degree angle and remove it. Hold the RAM by the edges only.
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
  6. Repeat step four with the second RAM.
    • Repeat step four with the second RAM.
Заключение
charlierefvem
Участник с: 11.01.2011
854 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 13-2, Forte Winter 2011 Участник Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 членов
Автор 8 руководств
Один комментарий
This is one one of the most essential part of the laptops because RAM(Random Access Memory ) is used to process and in the boot stage of any laptops. This website gives to best solutions and steps to change or upgrade your ram. Still if you have any confusion or want to talk to the Dell USA support then call or go their website.
edna taylor - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 3,258
