Введение
This guide requires a Phillips #00 screwdriver
Выберете то, что вам нужно
Slide the battery-lock tab and hold.
Flip the battery away from the chassis to remove it.
Undo the screw on the Mini-PCI card cover labeled "C"
Remove the panel from the chassis.
Use your fingertips to carefully spread apart the white plastic tabs.
Flip the Mini-PCI card up at a 45 degree angle.
Remove the card from the computer by sliding out diagonally
Еще один человек закончил это руководство.
