Введение
If you're experiencing any issues with the PCMCIA card on your Dell Inspiron 9100 or simply need to replace it or upgrade, this guide can guide you through with a step-by-step process. Keep in mind that PCMCIA can also be known as the PC Card, and it is also a major role in your laptop so by replacing it or upgrading it can enhance overall performance. Before you start on this make sure you have a compatible replacement card.
Press the same button again to eject the PCMCIA card.
Remove the PCMCIA card.
Push the popped-out button back in.
