Введение
This guide describes how to access the modem card and replace it.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Flip the computer over and place it on a clean level surface.
Loosen the screws using a size #0 Phillips screwdriver.
Once the screws are loose, open the panel using a plastic opening tool to access the components below.
Remove the screw holding the card in place using a size #0 Phillips screwdriver.
Gently unplug the card from the connecting black wire using a black spudger.
