Введение
This content will describe the procedure for replacing the WIFI Card.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Flip the computer over and place it on a clean level surface.
Loosen the screws using a size #0 Phillips screwdriver.
Once the screws are loose, open the panel using a plastic opening tool to access the components below.
Gently pry up on the gold antennae connections using a spudger.
Gently pry open both retaining clips on either side of the WiFi card using a spudger.
Еще один человек закончил это руководство.
