Введение
Use this guide to help you replace the hard drive in a Dell Inspiron 1305.
Выберете то, что вам нужно
Flip the laptop over.
Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol until you hear the battery click.
Slide the battery towards the back of the laptop until it comes free.
Locate the hard drive access door.
Remove the two 5.5mm screws with a #00 Phillips screwdriver. These screws are securing the hard drive access door.
Using your fingers, open and remove the access door from the laptop, exposing the hard drive underneath.
Еще один человек закончил это руководство.
