Введение
This guide will help you replace the heat sink in a Dell Inspiron 1305.
Выберете то, что вам нужно
Flip the laptop over.
Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol until you hear the battery click.
Slide the battery towards the back of the laptop until it comes free.
Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
Remove the bottom panel.
Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
Gently lift the heat sink from the side, as indicated in the picture.
