Выберете то, что вам нужно
Before any work can be done ensure that the laptop is powered off.
Use either the power button on the computer or issue a shutdown from the operating system.
Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
Locate the battery release switch on the bottom of the laptop.
Once located slide the switch into the unlock position.
Locate the “lip” on the laptop to lift the battery outside of the compartment.
Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
Once the new battery has been acquired take the battery and place it in the empty battery slot.
Slide the switch into the lock position to secure the new battery.
Remove the back panel: Use the screwdriver to remove the screws on the back panel.
Lift the back panel off the laptop to expose the interior of the laptop.
Locate the hard drive.
Remove the current optical drive.
Look at the model number and order the replacement if needed.
Insert the new optical drive in.
2 Комментариев
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
